TogaLake1988
- Jul 6, 2020
- 2
boat : 2008 Bayliner 185 Bowrider
Engine: Mercruiser 3.0L
Last weekend my battery went while out at a restaurant, when changing out the battery I stupidly connected the wrong side of the terminals. After doing so I had no power to the ignition but after doing some research I found and swapped out the 90A fuse in the starter solenoid and was able to get it running. Now this past weekend while out watching fireworks I found that my horn, front nav light( back post light works), stereo and accessory switch are not working. I changed all of the fuses under the dash, Would it be safe to assume that the small gauge wires running from my battery are fried and need to be replaced?
