Hey all!
I ordered a control panel from amazon that has 6 switches and a volt meter and 2 usb. Im installing it on an older bass tracker tourney v17 1989. The fuse panel is always hot and the switches are live regardless of the key switch position.
This is not what i want. I want the fuse block to only be powered when the key is in the on position. if i dont do this, the lights on the new control panel stay lit 24/7 or until i remove the battery terminal.
(red/light blue) is wire going to the fuse box for power.
does anyone know what color the wire is that is power on when the key is switched on? also where under the dash can i jump this wire to the fuse block?
thanks
thanks
