I agree with Stinnett21; this is an extremely simple modification. I installed the Mercruiser remote trim switch (see picture below) and it's connectors simply plugged into the existing connectors. You need to pick a good spot, then drill a largish hole (for the wires etc.), plus a couple of small holes for the screws to fasten the switch to the hull.
The trickiest part is drilling the hole; in fiberglass, I put blue painters tape over the spot where I would drill, then used a Forstner bit to get a nice clean hole with no chipping of the gelcoat.
This was one of the best value improvements I've done on my boat; it's so much easier to raise and lower the drive; no more climbing in and out of the boat just to drop the outdrive. It's also handy to drain the drive after a day on the river. If I were ever to replace my current boat, this is one of the first mods I'd make.
