I have a Minn Kota trolling motor (Endura 50lb) and I would like to extend the power cable approximately 5 feet, without cutting the original connectors. I'd also like to put a quick disconnect near the original leads. I'm thinking trolling motor terminals, to something, short 8 ga wire to disconnect, then 8 ga wire from disconnect to battery.
I've seen people who wrap and tape wire around the terminals of the stock lead but I'd like something a little more sturdy. Can this be done by simply using a small nut and bolt to connect the stock motor power cables to the terminals that will be coming off the quick disconnect (and taping/ insulating the connection)?
Tldr: What's the best way to extend trolling motor power wore while leaving the original terminals in tact?
Thanks.
Thanks.
