crabbycrabb
- Feb 10, 2019
- 9
Hokay! Thanks to Bondo for the tip on my ground problem, managed to take the boat for a shakedown run yesterday. It went great, no probs and took the wife and kids for a ride.
All was well until some weird stuff started happening, while stropping the boat to the trailer the bilge pump came on , which is fine as it has an auto float switch, i turned off the isolation switch before travelling the short drive home. When I got home, I started to get ready to flush the motor. I turned the isolation switch back on and whiskey tango foxtrot the starter motor fired up right away, with the key in the off position. I figured I could turn the key on and then use the isolation switch to activate the starter and then turn it back off again once the engine was running to get my flushing done. But now I need to solve this starter issue. Is it likely to be the key switch? Or do the solenoids have a habit of sticking? Hoping to solve this before the weekend. Thanks
