Lou C
- Nov 10, 2002
- 11,854
Most boats seem to have fuse holders added on to the battery or battery switch common terminal and most inboard gas boats have the battery and often the battery switch in the engine compartment. I came across this recently in figuring out my electrical issue. While you can buy a water proof fuse holder, these are not ignition protection rated (SAE J1171). However, some fuses such as those made by Bussman have the part between the 2 blades closed (other fuses leave this area open) and this gives them the SAE J1711 ignition protection rating. Just something to remember if you have a accessory wired to a battery or battery switch common terminal, in the engine compartment on gas boat....While the Bussmann fuses meet this standard, other brands of ATC fuses are open in the are between the terminals and do not meet SAE J1711. So if you use those water proof fuse holders in the engine compartment check the fuses!
