minus the shore power on board battery charger that has a wire going to the positive and negative of each battery it appears my battery’s are hooked up on there own separate grounds to engine and also have 1 separate positive wire going to the 1 and 2 on the dial battery switch. How am I supposed to keep both batteries charged. Your not supposed to run on “BOTH” right? Am I missing part or the wiring setup? I normally run boat and start on battery 1 and for all power when boat is off I use battery 2. After killing battery two I’m wondering how to set this up correctly ? Thanks
