Hi there
jcasemusic, welcome to iboats. Just as an quick fyi... Please know that It's often mentioned by a high quantity of members on forums such as these that if someone such as a service repair shop or service tech seems to have become quickly perceived as a possible bad match for your situation at hand, it's often suggested (or advisable) to go ahead and try someone else where/if possible.
With what was written above, and knowing AllDodge posting meanings, I could honestly foresee where AllDodge meant to try and lead you with his reasoning's of exploring someone new.....The important part is that you know him, like him and he is trying to help even if he hasn't had a bunch of experience with this exact mystery issue that you are experiencing at the moment...And he has the ability to reach out to others that may be able to help guide him through this together which may include your help as well. :eagerness:
So let's go-ahead and leave the above behind us now please and lets see if maybe we can be of any help or assistance to you in someway too... In order to do that we really do need your engine info such as engine model and typically a engine serial number tends to help out a few of iboats members even more to possibly help you out even better.
Being that the IAC motor system is of a 12 volt design vs the other sensors that uses a 5 volt system coming from the PCM, the IAC system is very capable of getting hot and on some engine models has been known in the past to create a small fire if not caught in time. Usually both the IAC and wire harness plug will start to melt which also in some cases will lead to the IAC driver inside the ECM/PCM to get burned/damaged which depending on how bad the damage is internally, the PCM might need to be replaced but there is now a company out there that now has the ability to diagnose and possibly repair PCM's that have a damaged IAC driver that is as long as you have the Mercruiser 555 design PCM.
If so, the last price I heard was 100.00 to inspect/diagnose and if it's repairable, it's 500.00.
https://whipplesuperchargers.com/index.php?dispatch=products.view&product_id=73
What area do you (the boat) reside in?
