The issue is your pics are to large. Need to set camera for less resolution, or use photbucket, or resize them.
Removing the hoses off the exhaust will take care of them, if they don't have plugs on the hose elbows. The block drains do need to be removed, one on each side and they do need to come out. They should be 7/16 nut head on them. Going to be a hard reach on the starboard side.
What can be done to make it easier next year is install a 1/4 NPT to 3/8 barbed hose fitting. Then add a piece of fuel line and another barbed fitting and plug. Then nxt year you can pull the plug on the end of hose and drain. If doing this method make sure to blow air up thru the hose a couple times to make sure it is clear and all the water comes out.
Not going to help you this year.
The wife and I are going out on the lake for a run and some lunch will be back later.
