In another of todays threads
http://forums.iboats.com/showthread.php?t=436445
it's mentioned that the posters mechanics thought the reason he found water in his engine was because he left the water pressure on his muffs while he re-installed the seats, put on cover, etc. Is this a real concern for running the engine on muffs? When I run my 88' 4.3 LX on muffs I typically am alone, so I turn the water on, walk to the boat, start the engine, do whatever I want to accomplish, turn off the engine, climb out of the boat, walk over 30-40 feet, and turn the water off. I never considered there should be a time limit on turning off the water. Is this a problem? From what I understand of the cooling system this shouldn't be a problem unless I have manifold leaks.
