Brandon12345
- Jun 12, 2011
- 29
Re: Troubleshooting problem on 79 Evinrude 100hp 100999S
I was finally able to find enough time try this. Shot fuel mix directly into the carbs but when I tried turning it over, the starter pinion gear wont even make contact with the flywheel. The pinion gear is ground down enough where it just wont make contact. Obviously I need to replace the pinion gear thing (i think its called the Bendix or Starter drive assembly, Part # 0385949). Does anyone know if I should replace any of the other starter parts while I am replacing this? I wasnt sure if there were any nuts, spacers, springs, etc that it makes sense to replace when you are replacing the bendix.yes you will have to remove silencer. Hold carb/s wide open and give a couple of good shots into them. allow them to back to idle and then try and start it. what happens? post back
