Re: Troubleshooting problem on 79 Evinrude 100hp 100999S
Hey brandon I have the same engine mines is a 85 hp. I have done this engine over to the point she fires right up. first things first Get the manual for this engine, it will save you tons of money and head-aches. 1 lets try to eliminate problem of fuel this engine is a 50 to 1 ratio get a spray bottle mix in gas with the correct amount of fuel, open carb throat and spray in some fuel if engine runs on the amout of fuel you spray in than there is no fuel comming from carbs.This is not as difficult as some make it to be,but take your time and get the kit, (Also)very important the fuel pump these are known to go bad with this engine there is just a rubber diaphram in the pump for suction. If you take out the two screws and prime the bulb you should get gas flow, if not check the screen inside has one screw for the cover. I looked at your pics, you should really get the book for your throttle setting and also choke link setting the black wire i see on the picture is for your (push to choke) ground, witch goes on your air silencer cover also the secound bolt looks like it is way to far in and this would prevent your engine from idleing down in the neutral position. I will give you as much help as i can according to the specs in the manual there is very little differance in 85 hp 100hp and 140hp rudes......
