pitprice
- Jan 20, 2010
- 23
I have recently purchased a cheap secondhand outboard I was told it was in working order but i have never seen it in action:
1972
Johnson
100hp
Model: 100ESL72R
Installed it all on the boat but the engine will not turn over/crank when i try and start it
First of all i assumed a problem with the amplifer as this has happened to me before on a previous similar engine i own:
1971
Evinrude
100hp
Model: 100193
Both engines are almost identical. The evinrude died a while ago but the amplifier is still good so i swapped over the amplifier and the coil to the Johnson and the engine cranked over fine However it would not fire, spark plugs seemed to be getting fuel so i assumed no spark. I have since found from parts catlogs that the amplifiers on these engines are not the same and this may explain the cranking but no spark perhaps.
See previous posts under 1970's 100hp Johnson and Evinrude compatability (http://forums.iboats.com/showthread.php?t=526071) for more details
i have reinstalled the Johnson amplifier and coil but still no cranking when i'm trying to start the engine??????
I have taken some photos and voltmeter readings below.
Any help would be awesome i'm a little stuck now.....
I have taken voltmeter readings from the wiring loom/harness at the screws number 1-12 left to right with: key turned off / key turned on / key on, fused removed.
1. 0 / 8.5 / 0
2. 0 / 8.5 / 0
3. 0 / 8.5 / 0
4. 0 / 8.5 / 0
5. 0 / 0 / 0
6. 15.1 / 14.6 / 15.2
7. no screw or wire present
8. 0 / 14.3 / 0
9. 0 / 14.4 / 0
10. 0 / 0 / 0
11. 0 / 0 / 0
12.
I'm hoping its not been sold to me with a blown Amp, fingers crossed.
1972
Johnson
100hp
Model: 100ESL72R
1971
Evinrude
100hp
Model: 100193
1. 0 / 8.5 / 0
2. 0 / 8.5 / 0
3. 0 / 8.5 / 0
4. 0 / 8.5 / 0
5. 0 / 0 / 0
8. 0 / 14.3 / 0
9. 0 / 14.4 / 0
10. 0 / 0 / 0
11. 0 / 0 / 0
12.
