Hello All.
My first time here and thanks for all your great posts, unfortunately i did not find an answer for what i need.
I have an Evinrude starflite 100s year 1966, It was running ok but sounded like it need a tune or carbs cleaned. So i was told to put the good shell gas in as it has techron and would give it a good clean. So i added the shell gas took boat out must of had some old fuel still in the lines as it was working like it usually does, then about 4 minutes at full throttle it started spluttering so eased of gas and was ok, anchored up, done some fishing, headed home. on the way back engine started coughing, spluttering, back firing , shaking and all sorts of things going on. Eased off gas and cruised back, then as i tried to dock i found out my reverse had gone, It was working before heading back so not sure whats going on.
Would the shaking, sputtering have had something to do with losing reverse?
I was told to drop the lower unit today then put in neutral and put it back, I tried removing the lower unit but doesnt come out, it moves about 2 inches. Is there something i need to do can anyone give advice to me please?
p.s i did mix some low grade fuel with high and it is running like it was before so i guess the fuel might of been running to hot or something?
hope for some advice
thank you
Degz
thank you
Degz
