Woodonglass
- Dec 29, 2009
- 25,924
If you're foaming the hull, and since the seats are boxed, a 1/2" glassed deck should be adequate in this case, in my opinion. If you're not foaming then 5/8" would be better. We're talking about 8 lbs per sheet difference.
Plywood Thickness and Weights:
Sanded Nominal Thickness
1/4 3/8 1/2 5/8 3/4 1-1/8
Actual Thickness
1/4 11/32 15/32 19/32 23/32 1-1/8
Approximate weight in lbs. per 4x8 sheet
22.0 28.5 40.6 48 60.8 84.5
Actual Thickness
