I'm going to move this engine from a 17ft CC to a 14ft CC so it's going to need re-propped.
Closest educated guess I can come up with is a 17 pitch prop...which still may be a bit under... as this is a very light boat
The boat is a 1987 14' Mckee Craft with a dry weight of 665lbs, 120lbs fuel, 110lbs gear and two persons.
The boat IS rated for 70HP.
I've tried the various "prop calculators" that I could find and most won't even return a result....one came back with a 22 pitch!!!
Is this 17P a reasonable starting point?
