Okay, well i'm an idiot. I was out on the water with my husband and saw that there were wires to the Trim/Tilt that were exposed. I decided that it was a great time to tape them up since I wasn't doing anything but getting sun and my husband was perfectly content fishing and catching nothing. So, the plastic or rubber that normally surrounds a wire was sooo dry rotted that most of it was gone. There was a little bit in between the two wires that was preventing them from touching, but apparently not enough. I went ahead and taped them together..thinking I was taking preventative measures. Nope, actually I made matters worse. Apparently there was alot more of the wires touching than I thought...so I am guessing that I shorted it out. So, now the Tilt/Trim won't work at all. It makes a clicking noise when the button is pushed but nothing moves. Is it possible that a fuse blew? How expensive is the fix? What can be done to fix it and get us back out on the water?
The motor is a 1995 40 HP Mercury Tracker 4 stroke.
HELP?
HELP?
