I recently won a new never mounted 26.5 inch diameter center pontoon with the motor well on ebay that I still have to go pick up. I plan to mount this to my 1997 Crestliner 24 foot pontoon that has 23 inch tubes.
Plans right now are to remove the engine and then the motor well slide the new center toon in place on the trailer and bolt it in place lining the front tubes up evenly. The new toon is 24'8" long total and has lifting strakes. It has a 2 pieces of channel welded to it length wise for attaching it so spacing is not a problem. The transom is also cut lower so the engine can sit lower in the water, remount the engine and see if I have any improvement. I live on a large lake and hope to get a smoother ride, allow a few more people to sit up front where the go anyway and maybe pick up a couple of mph when running from a storm. Boat has a 115 Yamaha 2 stroke and on smooth water with clean tunes can hit 30mph. Boat has submarined a few times when others have driven it in rough waves.
What type of bolts or fasteners would you use to fasten the toon with? Would using some rubber washer between the cross frames and the toon channel be a good idea? Anything I am not thinking about? 5150abf I know that you probably have more experience with making things work than anyone. Do you see any inherent problems with this? I got the center toon cheap, probably less than or about scrap value so I am not concerned about the money, but I realize that I am not a factory engineer or expert either. Thanks for any advise Carl
