j_johnson33
- May 26, 2009
- 17
I have a 1997 johnson 115 SPL at first start up everything is fine I can give it all the throttle I need the boat jumps up on plane. I can slow down and jump on it again with the same response. If I turn the engine off from then on when I give it throttle to get back on plane the motor boggs down. If I back off the throttle to about half it will start to pick up speed once it is on plane it is fine. if I come off plane same thing happens (bogg). What could cause the lack of response after the engine is turned off? Why dose it not do it when I first start out. Carbs were cleaned late last year,new filters/separator,plugs, fresh fuel, compression is 105-110 on all cyl. any suggestions? thanks in advance.
