chartersj
- May 14, 2013
- 281
I have been working on a project boat, i have replaced the block and trying to figure out why i am not getting spark. While cleaning connections i broke a stud off the coil, so i have a new one on it now. I have followed the trouble shooting guides which lead me to a bad coil, or bad ignition module. So i have a new coil, and i bought a module off a known running boat. I have 13+ volts on both side of the coil with the key on. I have 12.8 volts to the White/red going between the module and distributor. I dont get any spark on the white/green from distributor to ground. I am only getting 4.5 volts on the purple wire on the starter which has me puzzled. Also i have a purple wire close to the carburator with a black connector on the end not going to anything with 12+ volts on it with the key on. however i dont think it was connected to anything before. Any thoughts? How can i jumper out the kill switch?
