Re: tell tale blockage 3.3 mercury 2002
hey jon7,
I didnt know anything about outboards a year ago. I guess i still know nothing, but I have been able to fiddle around with a chinese one which was simple but poorly designed but I learnt a bit. I changed the impeller on my 3.3 2 weeks ago and have never done it before.
if you have worked on motorbikes doing what you said, this will be a breeze. all you have to undo is 2 bolts and open that rubber plug on the side of the leg and loosen the nut thingy (gear shift linkage) but not completely, just so it slides up the gear shaft (do that fist before removing the bolts. but best get on youtube look there and do more reading. its very easy, the only thing I had issues with was it was stuck in gear when I reattached it. so i started a thread and got the answer/help fix that issue and the other is, it has been a really big bastard getting the drive shaft back in while trying to line up the water tube. I can only laugh and picture you going through that as I did, it was really stressfull. I'm so not in a hurry to go through that again, but I will no doubt and it will give me the ****s hard once again, but hey thats life
