kcassells
- Oct 16, 2012
- 8,614
Anniversary date went great. Went to one of the Kohler American Club restaurants.
I am going to clamp like Frisco did.
As for the tapering, the old transom went the full width of the boat with fill between the edge and the side of the hull and no tabbing that I could tell. Instead of filling in that 1.5" depth I plan on placing a 45 angle on the sides for 3/4" leaving 3/4" thickness and filling from there. The strength will come from tabbing into the sides and will reduce how much filter I am using and make it easier to get the filling all the way to the bottom. For the top I am going to taper 45 all the way down to make an easy transition to the top of the transom. When you look how the transom wood is installed in Frisco's videos for a 454 and I am running two 4 cylinders, there will be more then enough strength. I am 42" tall at the center of the transom and running the full 84" width with a double layer of 3/4" plywood. The bottom of the transom at the hull will have no taper, will just be filled in with a filet like Frisco did.
Well LaTiDA for you two! Just went to the website and it sure does look like one great special place to revive wedding vows. I'm sure it was nice.
Yup Frisco boater set up is cool and works pretty good. I have also heard whichever way you go to make some rear holes in the transom fiberglass that lets air out and also lets you know the pb is down there. Just something I heard. Alot of guys don't want to do it cause then they have to patch it up later. Your call. I wish I did that when I installed my transom. Hmm come to think of it since I need to fix some holes back there maybe I will do alittle drilling for my own pc of mind.
Also I understand your concept with the taperring. Seems like a good plan. Now Go put your feet up and rest that back for the next adventure. lol!
