chrisrooter
- Aug 11, 2012
- 41
Ok, my prev. post was all over the map, not much help from anyone. here is a new question. I purchased a starter solenoid to install as mine was missing somebody removed and wired in a direct batt. cut off switch. which does work but feeds 12v directly to coil after starting somehow through harness. I wired new ss, with purple/black stripe to I side and yellow/red stripe to S side. both come out of harness. Along with batt. cables and feed cables to trim solenoids, but now turn key and nothing. there is no signal to starter motor. so i tinkled around and somehow blew internally the new starter solenoid. rewired in my batt. cut off andran a wire from yellow/red to starter as before and she fired and ran.
So, my question would be. is anybody kind enough to share what the correct wire colors would be in relation to my problem, I think the solenoid was wired right according to all i been seeing, but i dont know what wore feeds to starter other than the red batt. cable. thanks everyone for reading!
