Re: Spark plugs splash deposits (glazing)
very possible. many things, a full tune up would most likely correct. timing, carbs, compression, linc n sinc, running fuel higher than 87 octane.
Idles low and it's probably on the rich side. I need to set those carbs, needle valves, one by one is irritating.
linc and sinc is good.
Carbs have been gone through, fresh kits less than a year old.
Filter is new also.
Compression is good 100 is my lowest cylinder 105 my highest.
Timing was set by Evinrude timing tool. I'm not sure you can really set the low end with the tool. It has a detent tab for idle. Running those needles in brings the idle up.
Never used anything other than 87 octane. Might give 89 a try if it helps. I only run real gas, no ethanol.
One thing i forgot to mention, i've been running a electric fuel pump for the past year or so, 7 psi pump.Could that have anything to do with the splash deposits?
