My dad has a 1989 Stratos 4.3L with an OMC Cobra drive. Last year we had it out and the bilge pump could barely keep up with the water leaking in. After reading numerous posts I finally accepted that the transom could be rotten. It was hard to believe because this boat has probably not averaged one outing per year since it was new and it is always stored inside when not in use. I thought that the transom seal was bad or the nuts just needed tightening but looking under the boat I could see some discoloration and what looked like a crack in the fiberglass (see pic) under the mount. Today we decided to go ahead and pull the motor and see what was going on. I couldn't believe what we found. If you look at the pics you will see a line around the bottom half of the transom hole about an inch in. It turns out that when they (manufacturer) cut the hole in the transom they either had the wrong template or couldn't read a tape measure. They cut the hole wrong and instead of fixing it right they decided to just stick the cut piece back in, can't tell if they put some resin on it or not. You can actually see where they drilled the bottom two stud holes and then filled them in when they realized they screwed up. This wouldn't be a big deal but the first cut went below the transom seal level on the bottom. So for the past 25 years water has been trying to find the cut seam and now we have a mess. My questions:
1. Now that I know I have a rotten transom how do I fix it? My dad is going to take the boat to a body shop this week to get an estimate but I want to make sure it gets fixed right so this doesn't happen again. I would like to fix this myself but I'm not sure the best way to do it. We do our own auto-body work so I'm fairly confident we have the skills and tools to fix this.
2. I'm going to replace the transom seal, u-joint bellows, and outdrive gasket while I have it apart. What else do you guys recommend I fix why I have the motor out. I thought about replacing the gimble bearing but on a boat with so little hours I don't think I need to.
3. I have read that I need to buy a motor alignment tool especially since I have the motor out. Which one do I need? I saw one on ebay shipped for around $40. How do you use this thing? Do you just move the front of the motor around until it slides in easy then tighten the motor mounts.
Thanks for your help.
