Ok, I want to replace my mercury 90hp with Johnson 90 hp, do I need to drill new holes?
Both have power trim tilt
I am pretty sure the Johnson 90 is a 1982 model....at least according to the welsh plug numbers.
Just be forewarned. Changing from the Mercury to the Johnson is not just a simple "Bolt-it-Up type deal. You will need to change your controls and cables...along with the wiring harness of course. You will probably be able to use your Tach again...just change the pole settings. Steering cable should be the same....will have to change the steering arm however.
Ralph told me my 3rd and bottom cylinder was so out of whack that he bored to the next 2 size over
After you get new/used block , take it to someone else other than ralph as only way that cylinder would have not cleaned up is if it had a deep groove in it.....
