chrishayes
- Apr 9, 2009
- 691
Re: Project "1600 Capri Hard Top" has begun!
When it comes to weather sealing the cover have you ever looked at a soft top on a Jeep? Mine is a 94 and it uses a flexible aluminum channel across the top of the windsheild frame on top of a foam weather stripping then the top itself has a simple flat plastic rim on it that you stretch over the channel then you tighten the rear of the top by raising it slightly. This stretches it tight. Its simple and effective. I will try to take a picture for you. Depending on how wide your top is you may be able to buy the rail channel and a cheap bikini top to scavenge the plastic rail from. About 80 bucks total, and its simple plus replaceable for cheap.
