power head swap 70 hp evinrude
J JACKSON
will the power head off a 1978 70hp fit 1988 i found a great deal on one if it will fit my engine
pckeen
Re: power head swap 70 hp evinrude
Check the parts diagrams on marineengine.com
The powerheads look substantially different.
Bosunsmate
As above. Check the base plates gaskets. If they arent the same then its time to stop as they would have a different base plate face so the inputs and outputs from the gearcase wont line up
J JACKSON
ok if the power head i different will the foot on the 88 fit the 78?
Faztbullet
It will fit but you will need to use the complete 78 powerhead(ignition/carbs/linkages) and adapter plate as the 78 uses 5/16 dia. power head bolts and the 88 use 3/8 dia. Your also going to loose some performance as the 88 is a 56.1 ci and the 78 is the small 49 ci motor. Nothing will moun
bonz_d
Also the 1988 uses a 4 spline driveshaft. The pre 1984 uses a multi spline
Chinewalker
No, the fine spline didn't come into use until 1989. 1988 still used the 4-spline shaft. 1978 would be 4-spline. The 1978 and 1988 gearcases should interchange with minimal modification.
bonz_d
Could have swore that while looking for a replacement crank for my 1988 70hp that what I stated is what I'd found. Now I can't find those notes. Dag nab it.
J JACKSON
cool thanks for the help I am gonna go check out the 78 model Sunday if it is good i buy it and let you know how it works out, and i really don't think I will see much performance loss on a barge that might get 15 mph. All i really want to do is get back out on the lake
J JACKSON
well drove 2 hours to see a dang locked up motor, the guy said well it ran when i parked it. I guess i will be rebuilding the motor i have, everything i look at is either worn out or cost way more than me rebuilding mine will cost.
