Re: Oil/Fuel Mixture tester
jtexas; it is mixed by ratio, not weight, but I think you are on a roll.
I'm sure you'll agree that gas mixed with oil will be heavier than 100% gas........therefore, a gallon of 100:1 will weigh less than a gallon of 50:1....and a gallon of 30:1 will be heavier than a gallon of 50:1.......problem is, the precise specific gravity of gasoline depends on (apart from temerature) what's in it. Octane rating, oxgen content, MTBE vs ethanol....
But lets assume a weight of 6.3 lbs per gallon for 87 octane unleaded E10; if you know how much the oil weighs, you can calculate the ratio. Since we know its heavier than water, lets assume 9 pounds.
At those weights, a gallon of 50:1 premix would weigh about 6.35 pounds (.9804 gal of gas at 6.3 plus .0196 gal of oil at 9).
A gallon of 100:1 would weigh about 6.33 pounds. 30:1 would weigh about 6.39.
but to determine if you're over or under, you don't need the specific weights - you just have to compare what's in the tank to the same quantity of 50:1
