mudd_mickey
- Mar 19, 2007
- 39
Re: Newbie Lower Unit question
So you think it's the driveshaft that's stuck? I've seen posts where that happens and also the accurate but humorous response like iwombat said about turning the motor upside down and soaking the shaft with something like PB Blaster for a few days. That way is runs down the shaft into the rust. Great idea but not real practical for most of us.
The first time I ever did this job I though it was the driveshaft stuck as well and it was the shift linkage. I forgot to remove the bolt at the top of the linkage. Could you have more than 1 bolt on the linkage? I would not rule out the shift linkage until you can visually verify, by seeing light all the way around it, that you have it disconnected. Do you have a small mirror you can shimmy into there so you can verify the shift linkage is disconnected? Hopefully that's your problem cause if it's a rust at the top of the drive shaft it's gonna be some work. But.... PB Blaster should be your friend. Go buy two cans and use an entire one on that sucka! Then call it a few names and that might help. Also, try to stop using the hammer, I know it?s a hard habit to break but we get so involved and want to get it done NOW that those friggin hammers cost you in the long run. If you chip your lower unit you?ll be reading the post on repairing it next. If you need leverage I suggest a pry bar instead.
We could have an entire section devoted to "can't get my lower unit off".
Good luck and let us know how it turns out.
