Re: New tires won't hold air
I park all my trailers atop several cinder blocks topped with a 2x12 pt board.
I simply set the blocks up, then lift the boat and trailer onto them when I park it, the tongue is then jacked up to keep the bow well higher than the stern. That boat weighs only a few hundred pounds at best, I can easily lift the boat and trailer myself.
The boat cover completely covers the hull and hangs well over the tires. I also slip on canvas tire covers that were meant for a motorhome. Sunlight or ground contact should not be an issue. The spare is in the garage under a table with several others.
The part that I don't get is that I've got a trash can cart made from an old trailer axle with 480x8 tires on it, the tires on it are Goodyear brand and at least 25 years old, those show no signs of rot and I've not had to add air in years. The cart has no fenders, the tires are in full sunlight all the time.
The driveway and back yard are on a slope, I'd have to dig out a flat area to stack up blocks to support the axle rather than the tires. The boat and trailer are light, maybe 400lbs total, it doesn't even compress the sidewalls. The trailer GVW is only 700lbs on that one. My thought in supporting the tires vs. the axle is that PT wood would attach the steel axle and not likely hurt the tires.
I also flip the boat over for winter storage, plus a heavy tarp staked down all around. The other boat, about 1400lbs sits under a metal carport with two open ends, no sunlight gets to the tires and its parked on patio blocks atop 3/4" quarry stone.
Again however, this don't explain why the new spare rotted just as fast inside the garage.
Shipping far exceeds sales tax, local sales tax is only 3.5% here. The best price I got for shipping was over $65 for four tires. The tires were bit more locally but not enough to justify the shipping.
So far I've not found a single supplier that sells Carlisle, so far it looks like everyone has gone to only Kenda other than Tractor Supply who has Hi Run Tires.
