Re: New Sylvan 8522 CNF with RPT tubes Cracked welds
I believe what Hankson is saying is: Maneuvering a Sylvan equipped with RPT's at higher speeds, such as pulling a tube or skier results in very unstable handling characteristics. Believe the speeds he suggests are greater than the 27/28 your's will achieve. Mine handles like an old Ford LTD with a worn out front end wandering back and forth on a roadway with a slight crown. Add in a little cross wind in addition to the 1-ft swells and it is squirrely - much more than a standard toon. In my case, I've been operating pontoons for quite a while, about 25 years +.
Are you new to owning a pontoon by any chance? Pontoons don't really track well in water, so I can't tell if your issue is a "normal" thing, or if you really have a problem. I can tell you this, though, I have owned three pontoons. This one cuts through the water better than the other two I had and requires fewer steering corrections.
