Hello
I need some help with a used motor I just recently bought.
I took it out yesterday for the first time and was having some issues.
First off, when initial trying to start the motor it wouldn't start. We tried everything. Then we noticed that when we pulled the choke all the way out it would automatically go back in about a half of an inch. So holding all the way out and then pulling the string it finally started.
Then one of the mixture knobs is really loose and kept adjusting itself and moving around which I then had to clamp some vise grips on it to keep it from moving, then after that the knob broke off. So I need to replace that as well and find out how to keep it from being so loose and moving around. It seems liek the black seals that are around the choke knob and fast mixture knob need to be replaced as well, since they are broken. Picture is attached.
Then this morning I seen that there was some thick oil on the ground under the motor. It appears that there is a small hole right above the prop that is leaking oil. How can I fix this leak? Can I use JB Weld or some like that? There is a pictures attached.
I also want a carb kit to rebuild the carb. Where is a good place to search for all of these parts?
Also I am just going by the seller that this is a 1982 10HP...I am not sure if that is true or not. Can anyone verify that for me? I was looking into it and it seems that 1982 had a 9.9 not a 10hp. It doesn't say anywhere on the case that it is a 10hp.
Thanks in advance.
Thanks in advance.
