scout-j-m
- Jul 31, 2009
- 636
I'm in the process of testing my 1994 70hp Force's ignition system. All I have is a typical multimeter though so I have only been able to test the resistance of the stator, trigger, and coils (all were good). I need a peak reading voltmeter for the other high voltage tests but the cheapest one out there seems to be well over $100 and the cheapest adapter for common multimeter is about $70. Aside from buying the adapter, is there a place to rent these? I was hoping they had them at Autozone for tool renting but I haven't checked. Any ideas?
BTW, this motor sounds like it misses out on one cylinder occasionally at idle and when accelerating and at WOT it randomly surges and the power varies with consistent throttle applied. I had a mechanic take a look at the problem 2-3 years back and he said the stator was bad.
