mercruiser 350 starter grinding away
indigobluex
ill try to make this short and sweet lol.
i bought a 87 fourwinns with a mercruiser305 the starter had ground a notch in the flywheel upon further inspection i found water in the oil.
so i bough a mercruiser 350 and installed it in the boat with a new starter and a new flywheel i fired it up once last summer to check that the motor was good.
now i just got it out of storage and started it up and it started fine i tried it again and it just grinds against the flywheel. i changed the starter with just a normal car starter because i didnt want to buy a new starter if i didnt need to and i get the same just grinds away.
now if i pull the plugs out it will spin over just fine but it sounds terrible like the starter isnt meshing with the flywheel very good. i put the plugs back in and away she grinds again idk any thoughts any one
Fishermark
Re: mercruiser 350 starter grinding away
Did you find and fix the source of the water intrusion?
Leedanger
Ah ya....car starters won't work in most scenarios cause they rotate backwards.
Don S
Car starters turn the same directions as IO engines. Car starters won't work because the are not ignition protected and can cause an explosion.
Leedanger
Hmmm. Well apparently I received bad info probably the same way I just tried to spread it. Thanks for nipping it in the bud.
