Re: Making filler/putty
The old deck was put on before the top half was installed, and i would love to redo it that way, but i don't have the time and the help to. What I was going to do is just lay the plywood over the lip from the edges where it extends out over where the old wood was. Only problem is that the edges of the wood are going to create a "ditch" or dam for the water to sit in, and i know that is not good. My question is that can I make a filler w/ some polyester resin and wood dust? Ive got plenty of dust so i could make it as thick as it needs to be. I would make kitty hair or something like the peanut butter but the budget is the thing. I'm just going to fill the gaps with it and smooth it out to make a uniform rounded edge and like I said it's right against the wall so it wont be being stepped on.
Any opinions, or advice would be greatly appreciated
Seeing the the OP has not responded yet .. let me tell you why and how I posted as I did..and why some of the posts/ideas are premature. ( I do not intend to offend anyone here on This post )
READ HIS OP ! .. think about it ( I might be reading this wrong but..this is how Im reading it ).
1. DFM is going to lay down a Deck. Ok.. ( ply is glassed or resin coated ? .. nobody asked. Nobody asked for Pics.. ( Just HOW to do this with filler and spoons ). He has a "Gap" ( which was not defined and not seen .. could be 2"x3/4" who knows ).
2. He is Suggesting that the New Ply will be placed ON top of the Deck liner flange (
lay the plywood over the lip from the edges where it extends out over where the old wood was. ) So the New ply decking is going to be placed Over the fiberglass deck liner and Not in the ply decks original placement..
3. "Spoons" I never intended to offend anyone..but I kinda thought he was filling a Deck gap ( not a stringers ) . The Spoons work Great for stringers and bulks..but hes not talking about stringers. The radi of Deck to hull is a +90 deg angle. .. You can create your own angle with radi with the cutting/shaping of spreader. Its a trick of the trade..
3a. Spooning is good for Most fillet applicatinos..but not all. This application is still not entirely understood so my opinion is not against others .. but it might be..
4. Are the responses for his particular situation saying the he does Not have to tab in his deck to his hull ?
5. Fillers ( AKA PB ) are not always the same mix ( cabosil or microballons ) or ratio for the application. Some need more Cabosil..some might need some Glass bubbles. Some require longer strands of mat ( Thats Why I said no paddle Mix because Most of the Glass will just clog up your mixer when power mixing ). Structural mix should be done with Cabosil/resin and possible chopped up mat.
Are we Glassing the deck to hull in this application..or just Spooning in some filler for a deck thats raised and planted on a deck liner flange......?
I would say Dont just fill your new deck to a deck flange at all. If you did want to tie your deck wood ( that was below your molded deck liner ) I would ask for some Pics please..because the just Putty and Spooning is a bad Idea !
Unless we are suggesting that he should tie in his ply deck to his deck liner.. and also not Glass his ply deck to his hull..
I really dont think Im out of line here...
YD.
" But Yacht Doctor has HIS way and does not seem to recognize or credit, methods other than his own."
This has been given in my Sig " All Information or advice given by ME is from a Professional point of view and does not discount other methods by other members of Iboats. " I Do respect other methods from other members..
