Have to make some vinyl covered ply panels to create a good fit and finish between the plastic on the seats and the bracket.
Next will be to find a good deal on some height adjustable swivel bases, maybe with a slide.
Dorm fridge hater :lol:
You can't beat those 3 cyl 70 Johnnyrudes, good power, reliable and sip the gas.
4 holes for 1 cleat?
In the brochure pix you linked they look like typical 2 screw cleats, not 4....
Would someone have added a 2nd cleat just inside the 1st set? If so why?
Is that 'polished' oval of paint a wear mark just behind the upper left hole in your original 4 holes question post?
Pretty sure I have some 4 hole cleats around here or did you steal them GA.:laugh:
jb - I'd say that's a good call for either. Most cleats I've seen have a rubber or plastic pad under them. Maybe these allowed water to drain and no rubbing or vibration.
This is the same area after some fingernail paint removal. No wear on the original paint, no corrosion.
