Re: johnson 35 hp sea horse
You might try surfing EBay too. Most of the manuals there are for newer motors but you might find one for yours.
Also, depending on how mechanically inclined you are, a parts manual (avail here at iboats, $31.99) is often enough to do a lot of jobs, just because the parts explosions in them give a good idea of how things go together. Combined with a Seloc manual for torque info, gap settings, fluid specs, etc., getting the work done on this relatively simple motor isn't too hard.
One warning on the Seloc manuals, though - they aren't very good for the actual instructions on doing a particular job. This is generally true because they try to cover a very wide range of motors, and provide little info on any one of them. That said, in a pinch .....
