sutor623
- May 23, 2011
- 4,087
Re: Is this kicker enough motor?
Yeah that sounds like a plan. There is a company that sells longshaft kits for Johnsons, that has driveshaft and shiftshaft as well as extension piece. When I priced it for my 9.9 it was around $125. They are a bit hard to find at salvageyards, and about the same cost from what I have seen. Run the motor on water (or in a nice big strong bucket if you have to), and see if you can adjust the high speed carb jet to its best (fastest) running spot, then richen it up 1/4 turn. Youd be surprised how much power you will lack with a poorly adjusted high speed jet. Id do that first and see what you get.
