mtrainTurbo
- Oct 7, 2004
- 74
Re: IO or OB?
You're making an assumption that we're talking 2 strokes. Most newer 4 stroke outboards have closed the gap in weight, and if we're talking twin outboards to a single big block stern drive....
If its that shallow, you still aren't going anywhere with control because the prop isn't producing adequate thrust, and if you need to tilt the drive/engine up so that the blades are piercing the water, you may as well get out and push - you're on the bottom anyway.
But for the record, stern drives at idle speeds with reasonable tilt do not eat U Joints. My home waters are the Fox River Chain O Lakes, so I am well versed in shallow water sterndrive operation. Heck, I managed for 3 years with a Volvo Penta AQ that didn't even have power trim.
Again, location. Jack plates are not in common use on boats around here.
I would advise a lot of you to keep in mind his home waters. He should go down to his waterway and see what the majority of boats are using.
When you factor in his suggested price range (which is to say, pretty much nothing) he's shopping based on ONE factor, and only one factor: Condition for the price, and damn whatever is on the back of it. That means if he finds the worlds cleanest boat, but it has a Force OB on it, thats what he gets.
Nope, i disagree with your disagreement!
Given identical hulls and identical horsepower, the OB is going to have far superior shallow water capability no matter what. Two reasons
1) Outboards are lighter. A 200 hp outboard is 4-500 pounds. A similar v6 or small v8 setup is going to be 1000+ pounds. 500 pounds at the very stern of a boat is going to affect draft. This by itself means that if everything else is identical, the outboard still wins for shallow water capability.
2) tilt. Lets see you tilt an I/O up to the point the prop is just at the surface, and then come back and say how long your U joints last. OB's also have a mechanical advantage when tilted because of the higher pivot point, they get more of the lower unit out of the water and increase your shallow water capability.
3) (ok, i said i had 2, but this one needs to go in here also!) Jack plates... They don't work so well on I/O's, but they allow an outboard to go to the absolute minimum water depth. At slow speed you might be able to have the entire lower unit (or at least the prop) above the bottom of the hull.
