mlrman
- Jun 3, 2010
- 82
Hi,
I have one of those weird, intermittent problems that is hard to trouble shoot.
My 4.3 OMC usually runs great and hits about 4600 RPM at WOT with a little trim adjustment. This is the recommended RPM's for this motor.
However, all of a sudden, the RPM's will sometimes drop about 1000 RPM, and I can hear a popping or misfiring noise from the engine, and lose about 8-10 MPH.
Here is what's strange...I have noticed sometimes when this happens, if I shut off the engine and re start it, then it will run fine for a while.....but then it happens again.
Maybe a loose ignition wire or part?
I don't think it's timing, fuel, or compression, otherwise it would always have a low WOT.
The boat is a 1991 Sunbird Corsair CC with a 14.5" x 19 prop and will run almost 50 MPH @ 4600 RPM with just me in the boat....if I can keep it at 4600 RPM's though and thats the problem.
Thanks for any ideas!
