Inline 6 Exhaust Tube Installation
Hydro Mark
I have a 1968 Merc 1250 125 hp outboard. It does not have an Exhaust Tube and I found out, through some very helpful folks on this board (thank you members!) that I am supposed to have one. So I ordered one from ebay.
I have a Clymer manual and there's no info on the Exhaust Tube. On the picture (I don't physically have it yet) there are several holes and a bolt. Is it bolted in? Do I have to disassemble more than dropping the Lower Unit to install the replacement Exhaust Tube?
Thanks to anyone that can help.
Mark
Hydro Mark
Re: Inline 6 Exhaust Tube Installation
Ok, I ordered the lifting eye, exhaust tube and seals.
Now my question is.....Is removing the power head a DIY project?
Thanks,
Mark
Laddies
Banned
It's not difficult just time consuming when your ready I can PM you the removal process
Hydro Mark
Also, I guess I should ask......is there any required hardware that I might not have, other than the two bolts shown in the picture of the Exhaust Tube?
Thanks,
Mark
Hydro Mark
Well, I got everything apart and it seems to me that I have some variant the does NOT come with an exhaust tube. There are two different exhaust extension plates. My plate is a 48712 and has no way to attach the exhaust tube. The other plate (52932) does. It also appears there are two different drive shaft housings, a 3376 and a 3669. Mine is a 3376.
Can anybody shed some light on this? I'm really confused now.
[img=http://imageshack.us/a/img824/7669/ydvf.jpg]
[img=http://imageshack.us/a/img51/5556/z7vc.jpg]
Thanks,
Mark
merc850
Here's a cut open view of the whole engine and the housing page from the manual, the exhaust tube should bolt to the plate and go into a gasket in the LU
emckelvy
I've never seen one but they obviously exist! I found an eBay Australian auction where they sold the same plate:
Mercury 1250 Outboard Engine Tray TO LEG Exhaust Plate PN 48712 | eBay
Perhaps this was an early production model. The 1250 was a transition model, with 99 c.i. but still had the old flat-top-design pistons.
Maybe Merc thought this "open plenum" type of exhaust plate would work well, but I expect they found out the exhaust tuner/tube worked better. The latest part number for the plate is 48712A 2 so maybe they issued an updated version.
At any rate, I'm trying to figure out how loud your motor would be without an exhaust tube! The exhaust would be free to spill out the vents in the upper rear of the lower unit. With an exhaust tube, it'll all go down thru the gearcase and out the prop.
I have a feeling your motor will gain a lot of low-end and midrange response with the tuner, although I bet it runs like a Bat from Hades without!
There should be no reason why you couldn't find an exhaust tuner which would fit the center section and exhaust tube, since they obviously exist as well.
It does look like the part may be specific to the 1250, 'cause I looked up gaskets & tuner plates for early models 1150 and 1350, and they were different part numbers.
HTH & G'luck with the parts search.............ed
Hydro Mark
Thanks guys. I'm afraid that the drive shaft housing may be different as well. There are two different part numbers for them.
Hydro Mark
Mystery solved (mostly)....
Well, it turns out that my '68 1250 did not come with an exhaust tube. This was verified by a forum member with a factory parts manual. Have not determined if it's all 68's or just some of them. In any case, I'm putting her back together. I will try to find out if my housing will accept the tube setup.
Thanks for the help guys.
Mark
Hydro Mark
Mark
