NorthportTroller
- Jul 13, 2009
- 67
Force 35 H.P.
Model # 357P9A
Serial # 1012
US Marine Power
Hartford, WI
2 Cylinder
Cross Flow Induction
Engins has ran great until a few weeks ago. Idle started deteriorating. Will idle cold start, once it runs a little, it starts to stall. Getting pleny of fuel. There seems to be a problem with a possible exhaust leak inside the cover, because when I take the cover off it runs fine, but when I put it back on it will start to idle down and get rough and stall.
I can barely see a litlle smoke inside when the cover is off, it's not a lot. I checked the intake on the cover and it is free and clear. It is very hard to see where the leak is coming from, if any.
I tightened up some bolts here and there on any panels that had gaskets on them, and it is still running funny just with the cover on, at idle. Other than that it runs great.
Model # 357P9A
Serial # 1012
US Marine Power
Hartford, WI
2 Cylinder
