The upholstery on the bow cushions isn't original, and the carpeting on the platforms under them doesn't look to be original either. The OP should be able to open up those compartments from the top.Found a similar one (same year and model) and no apparent storage up-front: http://forums.iboats.com/boat-restoration-building-hull-repair/1989-capri-1950-budget-rebuild-restore-418521.html
I'm pretty sure that's not the way it came from the factory. One side should be a battery compartment and the other should have an insulated tray with drain to act as a built-in cooler. I'm becoming convinced someone did a restoration on your boat and did away with several storage compartments.The seats in the back are removeable yes but its open to the engine compartment. Any thing i put in their will just fall into the engine comp.
