Re: I need some help with a 1987 50HP Force
okay - new points, new plugs, new fuel pump diaphram, and a different carb. The engine starts and runs.
It sounds like its backfiring a bit after running it ~10 minutes. how rough should these run? As per the Clymers, I set my pointgap to .015 or as close as I could get to it with my feeler gauge.
I also noticed that if I put it in neutral and rev it up the motor struggles to come back to normal operating RPM. so, I adjusted the linkage for the throttle a bit and it slightly fixed the issue.
