The starter engages, and the flywheel spins, but no boom.
From what I can tell, I have spark, but I'm not getting any fuel beyond the carb. I picked up fresh fuel, mixed 50:1, and picked up some new plugs.
If I try and start it, I get the starter spinning the flywheel and then when it fails to start and the choke opens again, fuel comes out of the front of the carb. I checked the plugs and there isn't even any fuel on them... They are still as dry as they were out of the package.
On the carb itself, I see WE13 6/86 and 628061. I also tried looking up a rebuild kit, but haven't had much luck. Is there a PDF of this carb available anywhere or can someone give me a hand with a few Q's?
I took the carb apart, and cleaned it out. There is a brass sleeve over one of the needles that has 4 holes in it. Is that supposed to sit over top that needle and float freely? or does that get locked in place with the set scew?
How many turns are the adjustments supposed to have? Also, the spring for the float, how is that supposed to sit? Which way is it supposed to apply pressure on the float? That spring was a PAIN and I want to make sure I got it back in the correct way.
