I have a 2000, 5.7 duoprop with sporratic overheating problems.
I replaced the thermostat - no difference.
I suspect the raw water pump is bad but I replaced the impeller and seal last month. As an experiment, I disconnected the hose that goes from the pump to the thermostat housing and started the engine. (the boat was lowered on the lift just enough to cover the intake grate on the outdrive). No water came out of the hose. Suspecting I might have an air leak I pulled the hose from the pump suction side and sucked on it and was able to pull water from the hose. Should the pump be able to draw water under this condition?. I know when the boat is floating that the suction for the pump is probably submerged which makes it easier for it to get suction. Any suggestions?
