She did the right thing by asking someone.-------Maybe the tech had a busy day.
Agreed. I was happy they responded. Even more happy you guys set the record straight.
Whenever the oil line is disturbed as in changing the VRO, etc.... Be sure to prime the pump as follows:
(Priming The VRO Pump)
(J. Reeves)
When hooking up or installing a VRO whether it is a new or original VRO pump, it must be primed in order to dispel any air that might be in the oil line.
Have the Oil line attached to the engine fitting BUT detached from the VRO. Add a piece of fuel hose if necessary to the oil line so that it can be aimed into some sort of container.
Pump the oil primer bulb, catching the oil flowing out of the line into the container until you are absolutely sure that you have rid the oil line of every bit of air that might have been trapped there.
Now, connect the oil line to the VRO and secure it. When the oil line is secured, apply pressure to the oil primer bulb ONE TIME only. That's it.
This was what you stated in post #23... "I changed out the buzzer with a new one and also the tach with a new one. If I wired it straight to the ignition it buzzed all the time so I wired it back up where the old one was."
Where the old one was??... You'll need to be more precise than that.
The only horn that beeps when the key is turned to the ON position that I'm aware of is that expensive black piece of plastic that has a built in ground wire.
To run without the vacuum switch will need to be your judgement call.... however, from my point of view, since the warning will still sound constant and steady should the engine Overheat which is identical to the Fuel Restriction warning... no possible harm exists.
It's just a case that one must make sure that the warning horn beeps when the key is turned to ON... and that the horn does sound constant & steady when the key is ON (engine NOT running) and one grounds out either of the overheat sensors at the cylinder heads.
That leaves the operator of the craft to render a decision when (if) the engine looses power and is in the process of shutting down... Hmmm, is this a fuel restriction problem or did my warning horn suddenly fail... turning the key off, then back on should result in a beep to put your mind at ease.... as you hopefully see that the fuel primer bulb has collapsed somewhat due to a fuel restriction.
Now, if they could get that Fuel Restriction warning to do something altogether different than to duplicate a overheat warning... I'd have a different opinion of it. Playing "Dixie" would be nice! :fencing:
