Re: force power head swap
1990 was before Mercury changed the drive shaft splines. The 125 will swap right in with no problems. You won't need anything if the match plate and exhaust down tube are still on the 125. If they are not, you will need a gasket for the match plate to block. And yeah, you will need some silicone RTV to seal the match plate to the midleg.
