haulyard
- Dec 29, 2007
- 71
Re: Everything was fine until i fixed it (boat has mind of its own now)
this was origonal floor was no stringers only floor and foam,never gave it a thought when i cut out floor and pulled out foam,i did leave about three-four inches on sides and end to fasten new floor to but failed to support the hull to floor,oh well ,like i said earlier only was$45 bucks for boat, carpet was $30.00 bucks
not out two much...
i will try pulling floor again and throwing in all the foam and old life preservers i have lying around,and get about three guys inside to smoosh it down while i screw down the floor.
if that fails to work at least she still trolls for fishin
thanks for the advice,very thankfull for this forum.
Negative! The hull needs the stringers but the foam will give the hull some stability. My guess is that the stringers were gone and someone just filled the hull with foam to do a quick sale. If the OP were asking to properly fix the hull to keep it I would advise to put some stringers on it. I am not aware of any fiberglass hull of his type that has no stringers on it. Of course, I have not seen every boat out there...
not out two much...
